Plants in a flat
  • I am considering options to acquire depth information on a flat of small plants (10" by 20") and am considering the THREE for a fixed application using a single scan at a distance of around 800mm to the surface.   All that is required is collecting the scan using the api,  the conversion to a depth map would be on me.
    My questions are:
    -  Would plants be a candidate for a fixed single scan application a good deal of height variation in the scan?
    -  Would a slighter greater distance to around 900mm be possible in single scan mode,  allowing a slightly bigger scan area.
