I would like to try and use the MAF Three scanner with a separate rotary axis. Can a third party axis ( Closed loop stepper & controller) be controlled over the external interface? Can a third party axis be controlled by the API (via a DIY hardware interface)?
The plan is to have the Three scanner attached to a fixed position relative to the rotary axis. This is done trying to keep calibrations to a minimum/fixed calibration. Wanted to understand the possibilities/pitfalls before heading down this rabbit hole. Thanks!
