The desktop software is boosting the performance of THREE a lot.
Because of much higher processing power on desktop PC user can have much higher mesh and texture resolution.
It's mentioned that MAF3 has sony cameras with 13MP resolution, but for 3d scanning and texture only 3MP (2104x1560) images are used.
The limitation might come from lower processing power of device. But now with desktop version it should be no issue to increase the resolution of images for - at least - texture. This will allow to create high quality texture quality with 4k or 8k resolution, which does not make much sense with current resolution. It would be also great to have higher resolution for scanning but must probably the scanning speed will slow down because of much lower fps with higher resoluton. But as said, for texture this should not be a problem.
My request: Provide option to increase texture image resolution when using desktop software. This higher resolution should be also possible to be fetched by API so that i can update my custom HDR and cross polarization modification. If you could also provide experimental solution via API only i would be interested and i could use own external texture mapping process.
This will be great addition to the scanner for all existing users and make the MAF3 even more attractive for new customer.
