Turntable cable
  • I'm about to scan a large object but would still like to use the full benefit of the turntable. The connection between scanner and turntable may be a bit short.
    Is there any way to get an extension cord for the pogo pins connector ?
    Best Regards
  • Hi Karine-Johanne, The cable is the maximum length for its capabilities. If you are looking to scan larger objects, you have to put the object on a surface and take individual scans by moving the scanner around the object.
    best of luck
    -Drew
  • Thanks, that's what i thought. I guess I'll just use a large lazy Susan and rotate it manually then merge the scans.
