Release Notes 6.3 - 6.14
  • Heres a quick list of what's new in some of the versions lately.
    A quick reminder, please TURN OFF your subscription to nightly updates unless are very brave and want to risk breaking your scanner. This feature is for testers, and some customers who are experiencing problems so we can get them fixes quickly but at a greater risk.
    The next major update should feature some texture improvements, as well as a "What's New" modal when you update.
    In the meantime heres the notes from the last few versions
    v6.14.42
    What's Changed
    • New QA test for turntable to avoid some motor issues
    • Fixes for Nightly CI and versions
    v6.10.7
    What's Changed
    • Turntable Zeroing fix. Rotating a turntable in the scan setting will set the middle position for the scan.
    v6.5.3 - v6.8.6
    What's Changed
    • These releases were for testing new CI changes. No new features or bug fixes.
    v6.3.181
    What's Changed
    • Scans don't save all image data for the last project. Project reported sizes should be more acccurate
    • Update to the schema causes major version change to V6
    • Schema small tweek to meshing API name.
    • Scans with no triangles are removed from the project
    • Repair for some projects on imported that were old or modified
    • Merging is possible with a single mesh
    • Exclude deleted scans from download during download project
    • Upgrades encryption for RSA key for wifi password transfer
    • Bugfix for global alignment
    • Ability to rename a project (double click on the open project panel)
