Feature request: export to Google Drive/Dropbox
  • This is way lower on the priority, but when using a tablet/chromebook to do a capture session, it would be nice to be able to shut down and pack everything away after the capture is done.  But the resulting data will later be used on a different computer.  It would be nice if there was a way to export directly to cloud storag instead of having to use the tablet/chromebook as intermediate storage or having to run the THREE later to grab the data from it.
  • Hi Joseph! Thanks for the suggestion. I've passed it on to the dev team!
    Just to be clear, you want a way to export projects directly to cloud storage? The idea is that you do some scans on THREE using your tablet, but then want to edit the project on your PC using a program like MeshLab? And you want to avoid downloading the project to the tablet and re-transferring it to the PC or powering up the THREE again to download it directly to the PC?
  • Yes.  If I am doing a capture session away from my desktop (similar to the early example of scanning the air intake manifold while in the garage) and can successfully create the merged mesh that I want, it would be convenient to export that directly into cloud storage that I can access from the desktop.
