MAF3 with Cross Polarization Filter and external ligth
  • I have done some basic testing using cross polarization with MAF3.
    I am using this for photogrammetry and to me this is the holy grail to get outstanding texture quality.
    Cross polarization requires external lights where polarization between light and cameras are crossed by 90°.
    This helps to reduce light reflection on the object (white spots). Especially for bright objects this can be big problem. Most professional photogrammetry experts are using DSLR with ring flash and cross polarization.
    I am sharing this idea here in the forum to see if there is any willingness from dev team to support such expert features in the MAF3 software. It's not rocket science but HDR and use of external lights (with or without cross polarization) would require some processing options to make it easy to handle. At least running custom macro to define sequence of commands with different exposure setting for point cloud scanning and texture capturing would be needed.
    Feedback and discussion about this idea .... welcome!
    MAF3 and external lights equiped with polarization filter. Polarization from ligths and cameras are crossed by 90° to reduce light reflection a lot.
    Without cross polarization lot of reflections visible!
    With cross polarization used, the reflections are reduced a lot ... almost completely eliminated!
    GIF animation is showing the difference when changing the polarization filter on the MAF3 cameras from non-crossed to crossed position.
    I believe that use of external light (with and without cross polarization) and HDR support could boost the texture quality a lot and make MAF3 to a real differentiator compared to competition. The HW design from MAF3 supports such optimizations, but they will require some additional software support and updates. I am hoping to see support in later SW versions and to have some interesting discussions on the topic.
  • I am going to second a look at this potential solution to reflection of models for which scanning spray is just not appropriate.  I have a collection of tobacco tins from the 1950's that will never be produced again.  They are painted characters in a "Roly-Poly" shape.  Spraying would cover the character features and without spray the single light source of the THREE reflects in a tight little area.  Away from the center of the highlight reflection, the light falls off quickly.
    Now, it's not the most important scanning target; but, it would be nice to be able to capture these whimsical containers in full 3D for future generations.  And, this is true for all of the tin toys so popular in the 1940-1960 era.  Safety regulations killed the tin toy industry.  So, toys and containers of this type, that live beyond the 'junk' phase are destined to be rare antiques.  😊
  • After some further testing i come to conlusion that HDR is absolutely mandatory for high quality texture capturing with MAF3 cameras. This is valid also when using additional external lights (e.g. photo box).
    BUT ... when using HDR for texture with MAF3 cameras the image quality is outstanding! So much better compared to current implementation. It's must have feature to bring texture from MAF3 on next level.
    Texture quality out-of-the-box, without external lights, without HDR, without CP. Dark areas are under-exposed without lot of details. Increasing the exposure settings would lead to exceeding the saturation for white area because of low dynamic range of cameras.
    MAF3 out-of-box texture quality
    Improved texture quality with external HDR processing (3x images, normal/over/under-exposed), without external lights, without CP. All images captured with in-build MAF3 cameras. The texture quality is much better and the color range is increasing a lot. Also dark areas are showing lot of details. Drawback still are the reflections (white spots) because of quite shiny surface.
    MAF3 with HDR texturing (no external lights)
    Further improved texture quality with external HDR processing + external lights + cross polarization. Polarization filters added on MAF3 cameras and crossed by 90° to external LED lights. The texture quality is almost perfect. Light and dark areas are showing lot of details and reflections have been almost eliminated by use of cross polarization method.
    MAF3 using HDR + external Lights + Cross Polarization
    I think the results speak for themself?
    It would be a big mistake to not implement HDR solution to MAF3 SW because the texture quality is improving a lot without changing anything on the HW.
  • At what stage do you currently capture the three images?  Do you simply repeat the same scan three times at different brightness values?
    I assume adding HDR to the THREE would require a setting where 3 images are captured for each scan?
  • Correct! Currently i am repeating the same scan several times as you mentioned.
    1. First turntable scan with e.g. 8 scans + texture.
    Exposure, Gain, Projector optimized for mesh scanning.
    But also texture is captured, which will be later replaced with offline created HDR image.
    (Optional: If object has light and dark areas it might be needed to perform another turntable scan with higher exposure, gain and projector settings to also capture mesh from dark areas. This time the texture should be disabled. Later this second scan need to be aligned with first round and moved to the first project folder. Unfortunately MAF3 does not have HDR for point cloud capturing as many other structured light scanner have. So this workaround could be used.)
    2. Second turntable scan without moving the object. First HDR image (normal exposure).
    Exposure, Gain optimized for white/light area (no red indication indicating overexposure).
    Projector set to zero, external light switched on.
    3. Third turntable scan without moving the object. Second HDR image (overexposed).
    Exposure, Gain optimized for black/dark area. Light areas are extremely overexposed.
    4. Fourth turntable scan without moving the object. Third HDR image (middle between normal/overexposed).
    Exposure, Gain set to the middle of the values normal/overexposed.
    Same procedure to be repeated for another set of capture poses. E.g. Top/Bottom or Top/Left/Right
    Afterwards exporting the whole project (zip file) and creating HDR images using SNS-HDR Lite (Free Version) with batch processing. Only texture-0 (image from left camera) need to be processed because right image not used for texturing. The created HDR image will be used to replace the normal image from mesh scanning. Finally importing the modified zip file into MAF3 and create texture with new HDR images.
    For the moment this is the easiest manual procedure. If scan spray is needed (e.g. glass, clear acrylic, shiny, glossy, black object) then it's better to do first the HDR image capturing, then apply the scan spray and do the mesh scan at the end. Some self-evaporating scanning spray (e.g. AESUB blue) will disappear in 1-2h and next scanning pose can be done. By this best quality for mesh and texture can be achieved especially for objects with challenging surface.
    Another (better) procedure would be capture mesh scan, and texture images one after each other for every position. This is faster and more robust for inaccuracy of turntable movement and also better method when doing single short without turntable.
    Example from my windows batch file to create HDR images:
    REM Set path to SNS-HDR lite!
    set SNSHDR="C:\Program Files\SNS-HDR Lite 2\SNS-HDR.exe"
    echo Start to generate HDR images! Existing images will be overwritten!
    %SNSHDR% -da -dd -x1 -dramatic .\Scan-7\Textures\Texture-0.png .\Scan-13\Textures\Texture-0.png .\Scan-19\Textures\Texture-0.png -o .\Scan-1\Textures\Texture-0.png
    %SNSHDR% -da -dd -x1 -dramatic .\Scan-8\Textures\Texture-0.png .\Scan-14\Textures\Texture-0.png .\Scan-20\Textures\Texture-0.png -o .\Scan-2\Textures\Texture-0.png
    %SNSHDR% -da -dd -x1 -dramatic .\Scan-9\Textures\Texture-0.png .\Scan-15\Textures\Texture-0.png .\Scan-21\Textures\Texture-0.png -o .\Scan-3\Textures\Texture-0.png
    %SNSHDR% -da -dd -x1 -dramatic .\Scan-10\Textures\Texture-0.png .\Scan-16\Textures\Texture-0.png .\Scan-22\Textures\Texture-0.png -o .\Scan-4\Textures\Texture-0.png
    %SNSHDR% -da -dd -x1 -dramatic .\Scan-11\Textures\Texture-0.png .\Scan-17\Textures\Texture-0.png .\Scan-23\Textures\Texture-0.png -o .\Scan-5\Textures\Texture-0.png
    %SNSHDR% -da -dd -x1 -dramatic .\Scan-12\Textures\Texture-0.png .\Scan-18\Textures\Texture-0.png .\Scan-24\Textures\Texture-0.png -o .\Scan-6\Textures\Texture-0.png
  • Another comparison of out-of-box result VS using CrossPolarisation + HDR + imported STL from laser scanner. Importing external mesh is to get best mesh quality because structured light scanner cannot scan shiny and black areas very well. It's optional but good to have this possiblity in MAF3 software.
    The 3x HDR images are not perfect because some shift caused by inaccurate repeatability of turntable movements. Also some minor reflections caused by the projector which was needed to be removed in photoshop with minimal effort because the 3x HDR images must be captured with projector light to avoid "cannot triangulate points" error. I could not capture only texture images without need capturing also point cloud which does not allow to block projector light completely. Because of this issues mentioned it is mandatory to get SW support using this method using CP and HDR.
    @MAF dev team: Are you willing now to support HDR method for texture capturing? Also makro based solution which can be customized by user appreciated.
    MAF3 out-of-box texture:
    MAF3 improved texture using CrossPolarization + HDR + imported mesh from laser scanner:
    Setup using external ligths with cross polarizaiton filters on LED lights and MAF3 cameras:
    Using this method would allow MAF3 to become unique 3d scanner with outstanding texture quality. With handheld scanner this is almost not possible to use this method. Comments welcome!
  • Thanks so much for the explaination and new example!
    Very Impressive!
    Since we do not have a RAW image available, simplly using a photo app to process cannot attain the results you are demonstrating.
  • Hey Christian Gassner,
    Thanks for the amazing exploration and work.
    We'll look at adding HDR to the texture capture again.
    We did some research with HDR in the past, and found the big differentiator to be the use of external lights. Just having external diffuse lighting instead of the harsh projector light made a huge difference even without HDR. At the time we had bigger fish to fry so it got left on the back burner. I'll put it back on the feature list and see what we can do.
  • Thanks Drew for positive feedback. It's definetely worth to implement this because the texture quality is improving a lot. It's a huge difference !!!!
    I will draft a proposal from my side about the feature and procedure i am dreaming to have for HDR texture capturing. Everything i will request should will be doable and will be no rocket science but will allow to take over many other expensive scanner on the market including many other structured light scanners. With minimum effort we can achieve a lot on the MAF3 because the design allows to do so.
  • @Drew Shark I am so happy to hear what you had to say!  The issues with single source lighting are exacerbated by the fact that the reflections are repeated at every stop, albeit on a different feature of the part.  One of the reasons I bought my initial Roly-Poly's was to explore tryong to solve this very issue with the V2.  I have wondered, with the THREE if the WiFi could not be used to trigger some form of external lighting just for the image capture portion of the process.  Even very small external LED lighting with minimal diffusion would be welcome.  If the lights could be truned on/off via wifi then they should not interfere with the levels of light needed by the 3D rendering engine.
    By the way, with the V2 one of the things I tried was using the small Orangemonkie Halo lighting bars,  Very small, lite and effective for their size.
    https://orangemonkie.com/products/halo-bar-lighting-add-on
  • @Tom Meeks The reflections on glossy objects can be eliminated best when using external lights with cross polarization on lights and cameras. I also would like to have option to switch on/off the lights with MAF3 and for this simple HTTP GET request could be used. This could be arduino wifi switch (many such code available) but also commerical HW like Shelly Plug or Shelly Relay, Snoff Wifi Switch or ESP-01 and many others. Beside switching the external lights the polarization filters could be moved with simple slider in front (and back) of MAF3 cameras. This would allow to have full light sensitivity for scanning the point cloud. At least this option for this non-plus-ultra solution would be given by such feature in MAF3 software.
    @Drew Shark Here my proposal for the implementation of HDR and external ligth switching. Beside this i think it would be also good to have option for 2nd point cloud scan with different exposure settings. This would be "HDR Lite" solution for the point cloud scanning. For point cloud scan just the points from both scans should be merged into one. It's simple but very effective and also other structured light scanner on the market are doing it like this. Both improvements for point cloud scanning and HDR for texture will boost the performance from the MAF3 a lot! Based on the testing i have done manually it can deliver outstanding results. Almost not possible with handheld laser scanner. ;-)
    PROPOSAL FOR 2nd SCAN OPTION TO CAPTURE POINT CLOUD (HDR Lite)
    TESTING:
    GUI IMPLEMENTATION PROPOSAL:
    PROPOSAL FOR HDR TEXTURE
    GENERAL SETTINGS & PROCEDURE (for external light switching with http get command)
    I know that this will be quite a lot of work to implement but it will allow to fully exploit the potential of the MAF3. Everything which is requested here is "doable". This is just a first proposal and other implementation might be more useful.
    Looking forward to your comments and questions regarding this proposal.
    It would be amazing to get those features! Not only for me, also for many others!
  • @Christian Gassner I am interested in testing polarization.  Are your filter holders 3D printed or purchased?  If printed, I would love to have the .STLs you used.
    Also, I would like to know your source for the filters for both lights and cameras.
    I love your experimentation and interface suggestions!  This has been a terrific thread.
    Thanks,
    Tom
  • @Tom Meeks The filter holders are 3d printed. I will upload them to Makerworld tomorrow. For the time beeing it's very simple design for testing, but it works. I have made two options.
    One with 25.5mm circular polarization filter made from glass (Model: Hama, Silver Edition, 25.5mm).
    Another version with linear polarization foil, the same i am using for the lights but rotated by 90° (Model: Screen-Tech, ST-38-20, linear polarisator).
    The filter i have designed for the LED lights which i am using you can download here:
    https://makerworld.com/de/models/1499365-polarizing-filter-for-smallrig-rm120-led-light#profileId-1568309
    But for first testing you can also cut the foil and use some tape. ;-)
    By  using the glass version you might loose less light, but also with foil on cameras you can achieve excellent results. Using cross polarization makes only sense for texture. For scanning you would need to apply also filter on the projector and you will loose to much light which makes scanning extremely difficult.
    And for texture you only need to have filter for one camera because maf3 uses only image from left camera for texture. I would love to change it to right camera because it has more distance to the projector which would make it easier to use ringlight for texture.
    I am already working on next further improved version which will only use one filter for the left/texture camera. I will motorize this which allows me to remove the filter for scanning. For texture i want to switch on the lights and move the filter in front of the camera. More to come ...
  • I have uploaded the "experimental" filter on Makerworld which can be downloaded here:
    https://makerworld.com/de/models/2249701-cross-polarization-filter-round-maf3-3d-scanner
    https://makerworld.com/de/models/2249732-cross-polarization-filter-square-maf3-3d-scanner
    I am currently working on improved motorized version and testing version looks like this:
    @Drew Shark What about implementation of above GUI proposal? Idea could be also to have seperate professional mode menu which needs to be entered or activated (maybe licenced?) in the settings to not confuse normal users by to many options.
  • This is really cool stuff Christian. I will say that you should be able to get much better texturing results from THREE, using the regular method, than what you've demonstrated. That scan looks like the alignments and scans are misaligned, which is why the colors are so blurred together.
    For good texturing, you'll need to use a camera exposure that is light enough to see the colors well.
    I would recommend doing one scan for the geometry, therefore setting things appropriate for geometry only and not doing textures, and then doing a second scan for texturing. The second scan's geometry will not be as good.
    You then align the second scan to the first, then delete the geometry from the second scan (but it will keep the texture images), then merge, mesh, texture.
    That will give you optimal results, particularly when you have an object with light colors and black colors.
    Your product ideas are awesome but we can't comment on whether or not we will develop them.
