Ransac to align two groups
  • Hi,
    Could you please tell me what the correct API call is for using the RANSAC rough alignment method to align two groups?
    I’m currently using this:
    json
    Copier
    Modifier
        "Task": {
            "Index": 4,
            "Type": "Align",
            "Input": {
                "source": 1,
                "target": 14,
                "rough": { "method": "Ransac" },
                "fine": { "method": "ICP" }
    …but it doesn’t work.
    The object is roughly 50 x 50 mm and was scanned on two sides using a turntable.
    Could you please let me know how to correctly set this up?
    Thank you!
    Mehdi
  • Hi Mehdi,
    Great question.
    The task to align computes the alignment, but doesn't apply it to the model.
    When using alignment, you should listen for the response. The output from the response (if successful) will give you the transformation that you can then apply to the model.
    Here's an example of the task to align
        Task":{
            "Index":25,
            "Type":"Align",
            "Input":{
                "source":18,
                "target":19,
                "rough":{
                    "method":"Ransac"
                "fine":{
                    "method":"ICP"
    And here is the response
        "Task":{
            "Index":25,
            "Input":{
                "fine":{
                    "method":"ICP"
                "rough":{
                    "method":"Ransac"
                "source":18,
                "target":19
            "Output":{
                    "rotation":[0.0005511405177050501,-0.00027000695495325454,0.00048314887313871024],
                    "translation":[-0.018215706469504767,0.008557386007080225,0.042987728096079536]
            "State":"Completed",
            "Type":"Align"
    You'll notice there is a rotation and a translation component to the output. To apply this alignment to your project, simply call `TransformGroup` with the same ids of the groups, and the transform from the alignment.
        "Task":{
            "Index":27,
            "Type":"TransformGroup",
            "Input":{
                "index":18,
                "color":[],
    Here is some Python code as an example:
            # Run alignment on the project
            print("Starting alignment...")
            align_task = scanner.align(19, 14, rough=Align.Rough(method=Align.Rough.Method.Ransac))
            if align_task.Error:
                print(f"Error running alignment: {align_task.Error}")
                return
            print (align_task.Output);
            transform_task = scanner.transform_group(19, translation=align_task.Output['translation'], rotation=align_task.Output['rotation'])
            if transform_task.Error:
                print(f"Error transforming group: {transform_task.Error}")
                return
            print (transform_task.Output);
            print("Alignment completed successfully!")
    Please see the full python code for more examples
