Using ScanData functionality
  • I would like to download all scan data including the images captured from the stripe pattern.
    It it possible to get this images using the ScanData functionality?
    Please provide example for ScanData for use with javascript.
    Whole project file data via API is working fine but i do not get ScanData working.
    Thanks for help.
  • Hi Christian Gassner
    The scanData is used for downloading the 3D data of a scan (vertex, normals etc) and does not include images (other than textures).
    The pattern images are not stored on the device after capture and processing, so it's not possible to download then from a project. However you can simulate the result by turning on the projector and setting the projector pattern in the settings. Then you can use download the image from the cameras, change the pattern and repeat.
    I hate to do this, but I'm going to share untested code with you. I'm not near my scanner to test this for you but wanted to get you something to work with... apologies for the vibe coding.
    scanner-control.js
    const THREE = require('./three');
    const fs = require('fs');
    const path = require('path');
    // Configuration
    const CONFIG = {
        scannerUrl: 'ws://matterandform.local:8081',
        projectIndex: 0, // Use existing project at index 0
        outputDir: './output',
        projector: {
            brightness: 0.8,
            pattern: {
                orientation: 0,  // 0=Horizontal, 1=Vertical
                frequency: 3,    // Pattern frequency [0-8]
                phase: 0         // Pattern phase [0-2]
        camera: {
            selection: [0, 1],  // Both cameras
            exposure: 18000,
            analogGain: 256,
            digitalGain:  256
        capture: {
            selection: [0],     // Just camera 0 for image
            codec: 0,           // 0=jpg, 1=png, 2=bmp, 3=raw
            grayscale: false
        scanData: {
            index: 0,           // First scan in project
            buffers: [0, 1, 2], // 0=Position, 1=Normal, 2=Color
            metadata: []
    // Create output directory
    if (!fs.existsSync(CONFIG.outputDir)) {
        fs.mkdirSync(CONFIG. outputDir, { recursive: true });
    async function main() {
        const three = new THREE(CONFIG.scannerUrl);
        try {
            console.log('╔══════════════════════════════════════════╗');
            console.log('║  Matter and Form V3 Scanner Control     ║');
            console.log('╚══════════════════════════════════════════╝\n');
            // Step 1: Connect
            console.log('📡 Connecting to scanner...');
            await three.connect();
            console.log(`✓ Connected to ${three.url}\n`);
            // Step 2: Open project
            console. log(`📂 Opening project (index: ${CONFIG.projectIndex})...`);
            const project = await three.send({
                Index: three.taskIndex++,
                Type: "OpenProject",
                Input: CONFIG.projectIndex
            console.log(`✓ Project opened: "${project.name || 'Unnamed'}"`);
            console.log(`  - Index: ${project.index}`);
            console.log(`  - Groups: ${JSON.stringify(project.groups?. name || 'N/A')}\n`);
            // Step 3: Configure projector with pattern
            console.log('💡 Configuring projector.. .');
            const projectorResult = await three.send({
                Type: "SetProjector",
                Input: {
                    on: true,
                    brightness:  CONFIG.projector.brightness,
                    pattern: CONFIG.projector.pattern
            console.log('✓ Projector ON');
            console.log(`  - Brightness: ${projectorResult. brightness?. value || CONFIG.projector.brightness}`);
            console.log(`  - Pattern:  Orientation=${CONFIG.projector.pattern.orientation}, ` +
                        `Freq=${CONFIG.projector.pattern. frequency}, ` +
                        `Phase=${CONFIG.projector.pattern.phase}\n`);
            // Step 4: Configure cameras
            console.log('📷 Configuring cameras...');
            const cameraResult = await three.send({
                Type: "SetCameras",
                Input: CONFIG.camera
            console.log('✓ Camera settings applied');
            console.log(`  - Exposure: ${cameraResult.exposure?.value || CONFIG.camera.exposure}`);
            console.log(`  - Analog Gain: ${cameraResult.analogGain?. value || CONFIG.camera.analogGain}`);
            console.log(`  - Digital Gain: ${cameraResult.digitalGain?. value || CONFIG.camera.digitalGain}\n`);
            // Step 5: Capture image with projector ON
            console.log('📸 Capturing image...');
            const captureResult = await three.sendWithBuffer({
                Type: "CaptureImage",
                Input: CONFIG.capture
            if (captureResult.buffer) {
                const timestamp = new Date().toISOString().replace(/[:.]/g, '-');
                const filename = `capture-${timestamp}.jpg`;
                const filepath = path.join(CONFIG. outputDir, filename);
                fs.writeFileSync(filepath, captureResult.buffer);
                console.log(`✓ Image saved:  ${filepath}`);
                console.log(`  - Size: ${(captureResult.buffer. length / 1024).toFixed(2)} KB`);
                if (captureResult.output && captureResult.output.length > 0) {
                    const imgInfo = captureResult.output[0];
                    console.log(`  - Dimensions: ${imgInfo.width}x${imgInfo.height}`);
                    console.log(`  - Camera: ${imgInfo.camera}`);
            } else {
                console.log('⚠ No image buffer received');
            console.log();
            // Step 6: Turn projector OFF
            console.log('💡 Turning projector OFF.. .');
            await three.send({
                Input: {
                    on: false,
                    color: []
            console.log('✓ Projector OFF\n');
            // Step 7: Download scan data
            console. log('📦 Downloading scan data...');
            const scanResult = await three. sendWithBuffer({
                Type: "ScanData",
                Input: CONFIG.scanData
            if (scanResult.buffer) {
                const filename = `scandata-${timestamp}.bin`;
                const filepath = path.join(CONFIG.outputDir, filename);
                fs.writeFileSync(filepath, scanResult.buffer);
                console.log(`✓ Scan data saved: ${filepath}`);
                console.log(`  - Size: ${(scanResult.buffer.length / 1024 / 1024).toFixed(2)} MB`);
                if (scanResult.output) {
                    console.log(`  - Scan index: ${scanResult.output. index}`);
                    console.log(`  - Buffers received: ${scanResult.output.buffers?. length || 0}`);
            } else {
                console.log('⚠ No scan data buffer received');
            console.log();
            console.log('║  ✓ All operations completed!             ║');
            console.log('╚══════════════════════════════════════════╝');
            console.log(`\nOutput files saved to: ${path.resolve(CONFIG.outputDir)}\n`);
        } catch (error) {
            console.error('\n╔══════════════════════════════════════════╗');
            console.error('║  ✗ ERROR                                 ║');
            console.error('╚══════════════════════════════════════════╝');
            console.error(`\n${error.message}\n`);
            if (error.Error) {
                console.error('Backend error:', error.Error);
            process.exit(1);
        } finally {
            if (three.ws) {
                three.ws.close();
    // Handle cleanup on exit
    process.on('SIGINT', () => {
        console.log('\n\n⚠ Interrupted by user');
        process.exit(0);
    main();
    three
    // Enhanced THREE helper class for V3 Scanner
    const WebSocket = require('ws');
    function THREE(url) {
        this.url = url;
        this.taskIndex = 0;
        this.ws = null;
    THREE.prototype.connect = function() {
        this.ws = new WebSocket(this.url);
        return new Promise((resolve, reject) => {
            const timeout = setTimeout(() => {
                reject(new Error('Connection timeout after 10 seconds'));
            }, 10000);
            this.ws.onopen = () => {
                clearTimeout(timeout);
                resolve();
            this.ws.onerror = (error) => {
                reject(error);
            this.ws.onclose = () => {
                reject(new Error('Connection closed during setup'));
    THREE.prototype.send = function(task) {
                reject(new Error(`Task ${task.Type} timed out after 30 seconds`));
            }, 30000);
            const handler = (event) => {
                try {
                    const response = JSON.parse(event.data);
                    if (!response.Task || response.Task.Index !== task.Index) return;
                    if (response.Task.State === 'Failed') {
                        this.ws.removeListener('message', handler);
                        reject(new Error(response.Task. Error || 'Task failed'));
                    if (response.Task.State === 'Completed') {
                        resolve(response.Task.Output ?? {});
                } catch (error) {
                    // Ignore binary data or malformed JSON
            this.ws. on('message', handler);
                reject(error);
            this.ws.send(JSON.stringify({ Task: task }));
    THREE.prototype.sendWithBuffer = function(task) {
            let bufferChunks = [];
            let expectedSize = 0;
            let receivedSize = 0;
                reject(new Error(`Task ${task.Type} timed out after 60 seconds`));
            }, 60000);
                try {
                    // Buffer announcement
                    if (response.Buffer?. Task?.Index === task.Index) {
                        expectedSize = response.Buffer.Size;
                        console.log(`  Expecting ${(expectedSize / 1024 / 1024).toFixed(2)} MB...`);
                    // Task completion
                    if (response.Task?.Index === task. Index) {
                        if (response.Task. State === 'Failed') {
                            reject(new Error(response.Task.Error || 'Task failed'));
                        } else if (response.Task.State === 'Completed') {
                            const buffer = bufferChunks. length > 0 ? Buffer. concat(bufferChunks) : null;
                            console.log(`  ✓ Received ${(receivedSize / 1024 / 1024).toFixed(2)} MB`);
                            resolve({
                                output: response.Task.Output,
                                buffer: buffer
                } catch (error) {
                    // Binary data chunk
                    if (expectedSize > 0) {
                        bufferChunks.push(event. data);
                        receivedSize += event.data. length;
                        // Show progress every 10%
                        const progress = (receivedSize / expectedSize * 100);
                        if (progress % 10 < 1 || receivedSize === expectedSize) {
                            process.stdout.write(`\r  Progress: ${progress. toFixed(1)}%`);
                            if (receivedSize === expectedSize) {
                                console.log(''); // New line
                reject(error);
    module.exports = THREE;
    package.json
      "name": "scanner-control-example",
      "version":  "1.0.0",
      "description": "Control Matter and Form V3 Scanner",
      "main": "scanner-control. js",
      "scripts": {
        "start": "node scanner-control.js"
      "dependencies":  {
        "ws": "^8.17.1"
      "author": "",
      "license": "MIT"
  • Thanks Drew! Very useful information.
    I am making some good progress with API control:
